I would be concerned for the spindle bearings. From your photo is looks like things got hot enough to discolor the collet? If so then I expect the bearings would have got very hot as there's not much distance between the collet and the bearings.
The bearings on my spindle do have seals, although due to being high speed bearings they rely more on the labyrinth seal. These pictures should give you an idea what to expect:
Name:	P1000894 (Large).JPG
ID:	11359Click image for larger version.
Name:	P1000908 (Large).JPG
ID:	11360Click image for larger version.
Name:	P1000899 (Large).JPG
ID:	11361Click image for larger version.
Name:	P1000947 (Large).JPG
If this had happened to me I'd definitely dismantle the spindle and have a look at the bearings. It's not too difficult to disassemble the spindle - the only difficult bit is removing the nut on the collet end. You might be fine as it is, or you might find the oil/grease has burnt away and the bearings fail in a few months.
Thanks Jonathan, I am in two minds about opening it up. Part of me wants to open it up and check it out but then I think stuff it, keep running it until I have problems, and deal with the bearings then.?
