    Been a bit of a lurker for a while but I thought it was time to share - I recently built a 4x4 table using carriages and a z axis from Precision Plasma out of the US. Ron is a great guy - I would highly recommend him and his products.
    I welded up a table and built a water tray to match the requirements of the "iplasma" carriages.
    I used the Bladerunner mach3 based control system from CandCNC automation and it was pretty easy to hook-up and get going.
    I am running a Longevity Forcecut 42i plasma on the table. I am getting excellent cut results and the consumables seem to be holding up pretty well. The CNC port on the front of the machine allowed for a pretty painless connection to the Bladerunner system. It is pinned with a slightly different pattern than the Hypertherm units but it is well labelled and easy to figure out. For the $ this is an excellent value cnc plasma source.
    There are a couple pics of 20g cuts - top and bottom of cut straight off the table. Also a couple 1/4" steel results.
Name:	20g under.jpg
    All in all the table works great and I am now working on table #2
    PW
    Oops - thanks for moving the thread here.
    No problem, nice build!
  1. Plasma table build, first question....
    Last Post: 01-08-2014, 03:11 PM
  2. 4' x 4' plasma table build in Canada
    By 190-v8 in forum Plasma Table Machines
    Last Post: 29-01-2014, 12:27 AM
  3. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  4. 3M x 2M Plasma table build
    By MonoNeuron in forum DIY Plasma Build Logs
    Last Post: 01-09-2009, 11:11 AM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
