  1. #41
    I cannot change PB.02. If I do and then after autotuning I change it back to 2.2, it resets all motor parameters detected during autotuning and as I mentioned before, PB0.09 (leakage inductance) cannot be set manually.
    How much down in rpm can you go with your ABB drive in vector mode?
  2. #42
    Okay, but I would still try other ratios of the other parameters trying to get nearer 50%, as long as you apply the same ratio to all motor parameters.
    With the ABB it goes down to zero.
  3. #43
    I know the threat is more than a year old but I would be really interested if you have found a solution to the VFD issue...
    Just bought the same set up (SL-222E + 2,2KW Spindle) a few weeks ago and so far have not managed to get it to work in vector mode. Pretty much the same issue - the spindle cranks a few turns, then stalls throwing an OC (over current) error. Fiddling around with the settings following your posts got me partial success but I forgot to note down the steps and lost all again after another auto tune...
    Cheers!
  1. Build Log: Servo Drive and VFD with vector control
    By Jonathan in forum Electronic Project Building
    Last Post: 05-04-2015, 07:58 PM
  2. Need help with a sensorless vector VFD and 2.2kw motor.
    By kajuk in forum Spindles & Drive Motors
    Last Post: 29-01-2014, 06:09 PM
  3. Vector Linker , thermic cutting
    By CNCtoolsWorld in forum Manufacturer News
    Last Post: 28-02-2013, 04:55 PM
  4. bitmap to vector conversion
    By GEOFFREY in forum Computer Software
    Last Post: 29-12-2012, 06:32 PM
  5. Vector graphics AKA CAD for free
    By m.marino in forum Computer Software
    Last Post: 15-01-2009, 02:17 AM
