01-02-2014 #18
From the keypads (P0.02=0)
Tried both default 8kHz and the maximum 15kHz.Make a note of the setting for P0.06 then change it to 15KhzTried both E and P mode. No difference so left it at default 0 (E mode)Make sure PB.01 is set to 0 (E mode)They are left at defaults since changing them didn't make any difference. Btw, after trying to change PA.06 I cannot return it to default. The manual says it can be changed between 50% and 200% but I can set it only to 200 or 500. There are also other "quirks" I noticed:Are the PA group values set to default ?
1. P0.05 (Dec time) is dependent on P0.15 (lowest freq), P0.05 cannot be set lower than P0.15*10 - if I set P0.15 to 120Hz, I cannot set deceleration time lower than 1200s.
2. PB.09 (Leakage inductance) manually can only be set to 0.0 or 0.1
3. P3.09 has no effect on changing frequency using keypad - it always in 0.01Hz steps.
Seems like the firmware is quite buggy.Last edited by kajuk; 01-02-2014 at 11:03 PM.
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
Need help with a sensorless vector VFD and 2.2kw motor.
By kajuk in forum Spindles & Drive MotorsReplies: 0Last Post: 29-01-2014, 06:09 PM -
Vector Linker , thermic cutting
By CNCtoolsWorld in forum Manufacturer NewsReplies: 0Last Post: 28-02-2013, 04:55 PM -
bitmap to vector conversion
By GEOFFREY in forum Computer SoftwareReplies: 16Last Post: 29-12-2012, 06:32 PM -
Vector graphics AKA CAD for free
By m.marino in forum Computer SoftwareReplies: 1Last Post: 15-01-2009, 02:17 AM
