06-02-2014 #37
The current is similar to mine.
I've just noticed you did not ratio the kW, you should set PB.02 to 0.55kW
If that does nothing then ABB at first were thinking about putting parameters in as if the motor was 50Hz 3000rpm but then realised this would not work so they opted for 50% settings 200Hz 12000rpm and it worked. I'm thinking therefore that you could try other ratios that are closer to the 50% settings.
e.g. 7200rpm 120Hz 66V 0.66kWSpelling mistakes are not intentional, I only seem to see them some time after I've posted
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
Need help with a sensorless vector VFD and 2.2kw motor.
By kajuk in forum Spindles & Drive MotorsReplies: 0Last Post: 29-01-2014, 06:09 PM -
Vector Linker , thermic cutting
By CNCtoolsWorld in forum Manufacturer NewsReplies: 0Last Post: 28-02-2013, 04:55 PM -
bitmap to vector conversion
By GEOFFREY in forum Computer SoftwareReplies: 16Last Post: 29-12-2012, 06:32 PM -
Vector graphics AKA CAD for free
By m.marino in forum Computer SoftwareReplies: 1Last Post: 15-01-2009, 02:17 AM
