    Marchant dice cnc router with kress 800 milling spindle. Machine in photo is taken from the marchant dice website, my machine is very similer I can supply photos on request.
    This kit includeds the machine, stepper motors, drivers, and power supply and a variety of collets of all it needs to complete is a pc with a parallel port and a copy of mach3 or linux cnc (Free)
    I think this router is a good choice for milling foam and balsa wood, milling out tracks for pcbs and also pick and place projects anything much heavier than that and the machine becomes less accurate so bear that in mind. For learning cnc on, I think its worth the money but don't be under the illusion you will be able to hog out hard wood or aluminium.
    Im looking for £1200 it has had light use maybe 24hrs running and cost over £2000
    All the mechanical coponents are included,
    1. x1 Kress 43.0mm Spindle Mount
    2. x3 Nema23 Stepper motors (minimum 1.35Nm)
    Foot Print: 800x550mm (31 1/2" x 21 1/2")
    Working area: XYZ Axis: 550mm x 320mm x 75mm
    Translation - Ballscrew Ø x pitch (1 revolution = X and Y axis 5mm, Z axis 4mm)
    X and Y Axis: 16x5 assembled with zero backlash Ballnuts
    Z Axis: 12x4 assembled with zero backlash Ballnuts
    Linear: Guide Rails - Y Axis, 15mm profile rail and carriages
    X and Z Axis Ø20mm Chrome Plated Precision Ground Shafting, Linear Bearing
    Frame Manufactured from: Aluminium Profile
    Spindle Mount: Kress 43.0mm included
    Motor Mounts: Nema 23 frame
    Manufactured in the UK by Marchant Dice Ltd (worldofcnc)
ID:	11418Click image for larger version.
    I made this plectrum box using this machine and my laser cutter. All the cutting was done on this machine and it made a nice job. link to pictures here -> http://www.cncscotland.co.uk/portfol...m-shaped-box/#
    £1200
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  1. BUILD LOG: A3 Marchant Dice Kit
    By neo in forum DIY Router Build Logs
    Last Post: 03-03-2021, 11:54 AM
  2. Marchant Dice
    By agent17 in forum Marketplace Discussion
    Last Post: 06-06-2020, 11:06 AM
  3. Marchant Dice router no thrust bearings?
    By gavztheouch in forum Marchant Dice Machines
    Last Post: 05-09-2016, 02:23 PM
  4. Marchant Dice on eBay
    By irving2008 in forum Marketplace Discussion
    Last Post: 06-09-2008, 05:37 PM
