Thread: Help on building an enclosure
Thank you everyone for your replies!
Right to start with then I am going to draw it out on inventor to get a better idea of the layout
Main points to consider then:
1. Steel or aluminium cover. (whatever my workplace has available)
2. Hinged lid, with an earth point to connect it to the main case
3. Raised steel platform for mounting the components onto. This is then earthed to casing.
4. Star grounded earth setup, maybe a bus bar to make earthing easier, which is then connecting to casing earth point
5. Additional space for upgrading.
6. Cooling fan and filter setup. 2 intakes/1 exit
7. Suitable mounting holes for attaching to wall etc.
Anything else?
One other question, I'm yet to get my WC spindle. Does VFD need to be mounted inside the enclosure as well then?
02-02-2014 #2
Yes, read the manual regarding free space for cooling. For example mine needs no free space at the sides but needs 75mm clear top and bottom for cooling.
ABB model, top right
http://www.mycncuk.com/forums/gantry...html#post51392
Also at the bottom you can see the terminal rail, this doubles up as my earth bus bar because the earth terminals clamp onto the DIN rail which is earthed by the incoming supply cable.Last edited by EddyCurrent; 02-02-2014 at 11:50 AM.
02-02-2014 #3
VFD Doesn't have to be inside the enclosure but like Eddy says it does need cooling space if you do.
To be honest I don't Like VFD inside same Enclosure because it introduces high potential for noise interference on other components.
Also I like to see the VFD display and have it Set to Amp's this way you can tell when cutter is getting worn has the Amp's rise has it wears.
CNC 3020 Enclosure/Upgrade
By Pointy in forum Electronic Project BuildingReplies: 59Last Post: 27-10-2014, 10:20 PM -
eBay: 400x600x200 enclosure 40quid
By EddyCurrent in forum Items On eBay UKReplies: 4Last Post: 18-10-2013, 11:14 AM -
19inch Rack Enclosure - interference?
By Washout in forum General ElectronicsReplies: 12Last Post: 22-09-2012, 09:10 PM -
PCB enclosure ?
By manofgresley in forum Electronic Project BuildingReplies: 15Last Post: 10-08-2012, 11:47 AM -
RFQ: Custom sized aluminium enclosure required
By benbenrf in forum Projects, Jobs & RequestsReplies: 8Last Post: 26-10-2009, 04:16 PM
