Thread: Help on building an enclosure
VFD Doesn't have to be inside the enclosure but like Eddy says it does need cooling space if you do.
To be honest I don't Like VFD inside same Enclosure because it introduces high potential for noise interference on other components.
Also I like to see the VFD display and have it Set to Amp's this way you can tell when cutter is getting worn has the Amp's rise has it wears.
CNC 3020 Enclosure/Upgrade
By Pointy in forum Electronic Project BuildingReplies: 59Last Post: 27-10-2014, 10:20 PM -
eBay: 400x600x200 enclosure 40quid
By EddyCurrent in forum Items On eBay UKReplies: 4Last Post: 18-10-2013, 11:14 AM -
19inch Rack Enclosure - interference?
By Washout in forum General ElectronicsReplies: 12Last Post: 22-09-2012, 09:10 PM -
PCB enclosure ?
By manofgresley in forum Electronic Project BuildingReplies: 15Last Post: 10-08-2012, 11:47 AM -
RFQ: Custom sized aluminium enclosure required
By benbenrf in forum Projects, Jobs & RequestsReplies: 8Last Post: 26-10-2009, 04:16 PM
