    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    You'll need to check the datasheet for the resistors.
    The simplist option is to treat the load at switch on as a pure short circuit, which then gradually reduces to normal load.
    So assuming, 240V, with a 100R resistor, you're going to have a 2.4A flow producing 576W of heat.
    At 150R, current and power is reduced to 1.6A and 384W.
    These loads should only remain for under a second, so you need to look at the datasheet and see what the surge/intermittent max dissipation is for each resistor.
    The 5 and 10W is the continuous disipation rating, but they will have a much higher intermittent rating, typically given as 5, 10 and 60second intervals.
    Also keep on eye out for any maximum current ratings, otherwise your resistor will pop like a fuse before it even warms up.
    It seems there is a lot of power involved...
    The resistors are the most common and cheap ones and I cannot find any current or intermittent ratings.
    The resistors are looking like these
    I am a little perplexed why a soft start is required, if it is to avoid a spike at switch on/off then a triac with a zero crossing detector would seem to be better.
    For 630VA you'd probably get away with it. More interestingly, the best point to switch on is actually when the mains voltage is at a peak - see here.
    I thought the same but for no apparent reasons I am unable to turn on my router. My 16A main fuse is tripping. After a few attempts I managed to get it on but later on trying again I manage to blow the T4A fuse at the toroid.
    The only reasons I could think about are the temperature drop in the workshop (7°C) or some alterations on the mains electricity supply.
  7. The Following User Says Thank You to EddyCurrent For This Useful Post:
  8. #7
    The T4A fuse was just fine, I'll change it with 6.3
    I have to check if the MCB is type D. Until now I did not know that there are different types of mcb's based on the instantaneous tripping current.
    But my question remains, if I want to implement a soft start will the cheap 10W resistors work?
  9. #8
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Have a read through this :- http://sound.westhost.com/project39.htm there are quite a few posts on this forum regarding " soft start " I have had many in my time usually after a .. Clive
  10. The Following User Says Thank You to Clive S For This Useful Post:
  11. #9
    Now, after a little bit of digging around t'Interweb, I realise the problem- it's big toroidal transformers needing a high-current fix at switch on. As I haven't used a toroid for anything other than power supplies for pre-amps and mixers I have not had a problem like that to solve. I must pull the case off one of my 1KW PA amps to see what that uses to switch on the power to the toroid in it.
    Never got round to that Laplace stuff at Uni, it was over 50 years ago and I studied Geomorphology
  12. #10
    A contributing issue is CNC power supplies have a nice big capacitor to charge from nothing at switch on, which contributes quite heavily to the surge.
    Placing a resistor inline, limits the surge until everything reaches working voltage.
  1. Opensource machine for dedicated soft tooling?
    By gavztheouch in forum Moulding Machines
    Last Post: 10-02-2014, 10:27 PM
  2. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
  5. Scrool jaw ring for hydraulic soft jaws.
    By Pmac in forum Tool & Tooling Technology
    Last Post: 28-01-2010, 07:55 PM
