Thread: Soft Start Advice
I thought the same but for no apparent reasons I am unable to turn on my router. My 16A main fuse is tripping. After a few attempts I managed to get it on but later on trying again I manage to blow the T4A fuse at the toroid.
The only reasons I could think about are the temperature drop in the workshop (7°C) or some alterations on the mains electricity supply.
13-01-2015 #2
Take a look at this;
http://www.ft-transformers.co.uk/wp-...ction-50VA.pdfSpelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
13-01-2015 #3
The T4A fuse was just fine, I'll change it with 6.3
I have to check if the MCB is type D. Until now I did not know that there are different types of mcb's based on the instantaneous tripping current.
But my question remains, if I want to implement a soft start will the cheap 10W resistors work?
14-01-2015 #4
Have a read through this :- http://sound.westhost.com/project39.htm there are quite a few posts on this forum regarding " soft start " I have had many in my time
usually after a
.. Clive
14-01-2015 #5
Steady now, remember what happened last time http://www.mycncuk.com/threads/8251-...5238#post65238
I'm currently on with that myself but it's black nectar
15-01-2015 #6
Opensource machine for dedicated soft tooling?
By gavztheouch in forum Moulding MachinesReplies: 3Last Post: 10-02-2014, 10:27 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM -
Scrool jaw ring for hydraulic soft jaws.
By Pmac in forum Tool & Tooling TechnologyReplies: 4Last Post: 28-01-2010, 07:55 PM
