Thread: Plasma floating head...
31-01-2014 #1
Looking at adding a floating head to my new build, I've found some code that goes in sheetcam to be run before a cut, this lifts the head, drops it and zeros the DRO etc, what I can't find is where the signal from the floating head micro switch is fed into the mach3 system??
Is it just another limit switch? Or does it need a seperate input signal?
cant find any information on this bit.
i guess a limit will do it as it will only close when the torch has hit metal, but wouldn't that trigger an e-stop??
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
