Thread: Plasma floating head...
Post the code because chances are it uses G31 and the Probe input.? It could also need a Macro.?
Edit: To be honest this could easily be done just by modifieing the M3 (Spindle on) macro to use G31 command and the probe input. It would then set all the Dro's etc and pierce height etc from within the Macro. All you would do is insert M3/M5 in the G-code which you may be doing anyway for torch on/off.?Last edited by JAZZCNC; 01-02-2014 at 02:38 AM.
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
