Thread: Plasma floating head...
01-02-2014 #4
To be honest I don't know enough about THC or Plasma related stuff really to confidently advise.
If all your wanting to achive is to probe the surface then retract to a set height along with zeroing DRO's etc then that's easy enough done but you'll need to either alter an existing Macro like M3 or create your own. This macro reference you then have SheetCam insert into the code it produces at the points it's needed.
If your wanting proper THC in that it follows a set distance from the surface then that will probably be differant matter.?
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
