Thread: Plasma floating head...
01-02-2014 #5
I have had a look inside the post code for the mach plasma with THC option in sheetcam and it has the code for G31 seeking so it just needs some options altering and the floating head switch wired to the probe input I think.
basically all I want is to have the torch seek the metal at the start of each cut then raise to pierce height and start.
i also want to retain the top limit switch for the "home all" feature in mach.
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
