    Brilliant,
    so where do I find this macro method ?
    sounds much better
    or I could alter the post to issue a g92.1 at the end of each run?
    Brilliant,
    sounds much better
    Just try searching the Mach3 forum and look at the Wiki for it's Commands etc.
    Yes you could just have it insert g92.1 and maybe thats how it's done in plasma but me personally I would use the more conventional Macro approach.
    To be honest I'm sure I've seen some thing around for Sheet Cam that use's modified M3 spindle Macro to do this very thing you want.? If I was doing it that's how I'd approach it and just have sheet cam insert M3 in the G-code.
  1. NEW MEMBER: In over my head
    By Tele45 in forum New Member Introductions
    Last Post: 03-01-2014, 02:30 PM
  2. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
  3. ballnut housing and floating end ballscrew assembly
    Last Post: 12-07-2013, 08:22 AM
  4. non-locating / floating bearing - shaft location
    By dsc in forum Linear & Rotary Motion
    Last Post: 28-06-2013, 10:07 PM
  5. Driving floating end (ballscrew)
    By blackburn mark in forum Lead Screws, Nuts & Supports
    Last Post: 11-09-2010, 11:55 AM
