Thread: Plasma floating head...
Sorry Dave I've been busy and had no time to reply regards Code. I'll have a look at what you put earlier and get back to you thou other than checking OEM codes etc it looks about right.
Only reason I can see for higher switch is in case material sprung or fell between grid and angled up slightly then you'd have some clearence for traveling between pierce points.?
06-02-2014 #2
Thanks, I'll try lowering it tomorrow, can't see any point in wasting time while it just goes up and down :)
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
