Thread: Plasma floating head...
Yeah, I've got it working nicely now by using a sheetcam post, there was bit of early confusion because it appeared the post did not work as good as it does but the author then realised that he fixed it a while ago and forgot it :)
it it does exactly what I wanted it too.
29-12-2014 #2
Any chance of you helping me out with the same problem on a new IHS design. I followed the thread but don't see a final solution. A newbie with Mach3/Scam and could use a jumpstart. Is THC required to do an initial IHC or can the software and IHS top switch do it all? Macros (code) and IHS switch input info would be greatly appreciated.
01-01-2015 #3
No THC is not required for the IHS but IHS is required for THC :)
the he top switch will provide the response for the IHS which is triggered by the code generated by the CAM software/post, the THC if used will then try and maintain that height based upon the voltage created across the arc, this varies with height.
there are many sheetcam posts that have the IHS code, I'm using ones designed for my THC system so you need to find one that will do what you need, have you tried the sheetcam forum?
Note, some THC systems do not need the code as they also deal directly with the IHS too as a total system.
dave
The Following User Says Thank You to Davek0974 For This Useful Post:
NEW MEMBER: In over my head
By Tele45 in forum New Member IntroductionsReplies: 8Last Post: 03-01-2014, 02:30 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
