Page 1 of 4 123 ... LastLast
    STAFF EDIT:
    This thread is a continuation of a discussion from another thread; the threads have been split in an effort to support the main topics of both discussions. The other discussion was a request for a quote on having a machine part made:
    Hi Doddy,
    3hrs drawing, set up and machine, £75, £10 material (finished item 24mm thick) and £12 registered post from Cork. Two lads in front of you at the mo but I could have it in the post for you by the end of the week. PM me if you want. Sorry for the short reply, missus has me banned from working Sundays.:)
    Rgds,
    Noel.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Noel - Thanks for the reply - for you and others possibly reading this I'm hopeful that I've got someone set up to produce this.
    For now, then - I think the request is in the process of being fulfilled.
    Thanks all.
    Last edited by Doddy; 26-01-2014 at 02:25 PM. Reason: Changed user name to real name... much more polite
    Quote Originally Posted by corkcnc View Post
    Hi Doddy,
    So £97 total...
    If you want it done by the end of the week for £35 including postage, let me know and I'll get my friend to cut it on this machine from 25.4mm (1") thick aluminium.
    So £97 total...
    Not here to argue but I wouldn't leave a part out the door for a machine without skimming both sides so when the part is repositioned for the drilling, that the edge face is perfectly square to flat face and all the imperfections left from when the stock was rolled are eliminated. These things all take time to get right and hence the 24mm width too.
    You can argue in this case that the bore and edge are in the same plane so the angle between the flat face and bore doesn't matter a fig but if there are holes going in the side and even if they are clearance holes, I'd still rather do it spot on for when it is repositioned.
    I can't comment on your mates work, I'm sure he's a damn fine machinist but I've seen too many things end up on my desk after jobs by people who have ignored the small stuff and it results in spindles misaligned and tapers on edges. Hence I'll stick to my ways and even if the skimming, clamping and clocking takes extra time, I know what goes out the door is good. If something gets past me, I know it's my fault and replace a part immediately.
    I must stress that this isn't a dig at you Jonathon, I have read a lot of your posts and have a lot of respect for you - you know your stuff. But this is how I operate unless a customer requests that cost is the major factor.
    Rgds,
    Noel.
    I hear what you're saying regarding maching the faces square, however I've rarely seen people mount things that require such accuracy to the spindle mount, so didn't include it in the price. Since the bed of the machine is machined/set to be in the same plane as the machine X&Y axes, then the only inaccuracy introduced would be due to the (lack of) flatness of the material, so the top of the part would be further from square than the other side. However if the customer required greater accuracy, then I would happily add £6 to the price and skim it accurately.
    When I make spindle mounts in two parts, such as those for the 80mm spindle, I use the surface plate and height gauge to measure the center height of each mount to ensure they're both within 0.01mm of each other. This is also one of the reasons why the rotating ballnut mounts I've made take a long time to machine - it's important to ensure the shaft is parallel to the mounting face(s), which necessitates careful consideration of the machining order, and accurate alignment...then someone mounts it on bits of welded box section and it's a bit demoralizing!
    Anyway, the reason my friend and I can afford to machine this so cheaply is lack of overheads. I just do this to fund my hobby, which is having a workshop. I therefore only charge up to £10/hour and add the cost of materials and postage. If the part is particularly interesting (i.e. complicated, like this one) to machine I charge less per hour. So for the spindle mount, it's about 2.5 hours work plus £5 for the material (@£5.50/kg) and £4 for postage, so 2.5*10+5+4=£34 so I rounded up to £35. I don't charge for CAD as it generally only takes a few minutes and I can do it any time.
    If I had to pay rent on the workshop and was doing this as a business, then yes I expect I would have to increase the hourly rate, however at least with having made the machine(s) myself I'm not having to charge lots to pay for the machine.
    So £97 total...
    This is what triggered my post.
    From corkcnc's post I have assumed rightly or wrongly that he is a legitimate company and just wanted to point out to Jon its all very well under cutting someone else's price but when you don't have overheads and don't pay your dues and demands its not fair to make out someone is charging too much.
    If Jon had just posted that he could do the job for £35 and left it at that then maybe I would not have posted.
    I am not having a go at Jon just wanted to point out sometimes its best just to think before you post.
    Andy
    Doddy's Avatar
    Thanks Jonathon, for now I think I'm sorted, although if there's any problems with plan A, I'll be certain to get in touch.
    Postage and material being a fixed cost £75 is not a bad price at all for the actual work/labour. People forget the amount of time needed to complete a one off job like this + cost of tooling, electricity, machine repairs, secoundary workshop tools to buy and maintain, etc. If you kept doing jobs like this for £35 including postage and materials you would quickly go burst in a real world scenario.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    It might be a hobby Jon but you are earning an income which is taxable!
    I have just finished filling out my tax return on earnings from my "hobby" machine.
    Start to take this into account and you can soon start to see your charge out rate increasing.
    Quote Originally Posted by audioandy View Post
    Only if I earn greater than whatever the threshold is, and I'm nowhere near that.
  1. Best type of shed.
    By Philly in forum General Discussion
    Last Post: 03-11-2018, 08:17 PM
  2. Commercial CNC machine lifespan?
    By sarahloyd in forum Machine Discussion
    Last Post: 24-01-2014, 02:21 PM
  3. Commercial Machine choices...
    By jashington in forum Marketplace Discussion
    Last Post: 10-10-2013, 10:38 AM
  4. NEW MEMBER: from a shed in Nottinghamshire
    By Andrew Wilding in forum New Member Introductions
    Last Post: 17-09-2010, 12:34 AM
  5. Commercial Sieg X1 anti backlash nuts ?
    By cweeks in forum Milling Machines, Builds & Conversions
    Last Post: 28-05-2009, 06:41 PM
