Has anyone ever machined stainless or titanium? I have a feeling even a Bridgeport knee mill would struggle and that is way beyond the strength of a home brew cnc. Would it be possible to use something softer and then have it induction hardend after machining?
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
04-02-2014 #2
The description "stainless" covers a very wide range of alloys - some are quite easy to machine, others difficult. A Bridgeport in decent nick shouldn't have any problem with most varieties in the sizes we're talking about here. I've cut it on a horrible Clarkes combi lathe / mill and while the finish wasn't like glass it was ok, The chuck is still covered with the residue from the vaporised coolant though (no flood coolant, just a hand held spray) :-)
Similarly, Titanium comes in a wide variety of alloys and tempers but a good quality mill should cut most of the alloys ok if you get your setup correct (cooling, fixturing, tooling, feed rates etc).
http://www.kennametal.com/content/da..._Aerospace.pdf.
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
What kind of machine will do stainless steel or brass engraving
By JayPunchbuggy in forum Machine DiscussionReplies: 8Last Post: 13-03-2013, 10:40 PM -
Flexible Stainless Steel pipe that holds its shape?
By Fivetide in forum Marketplace DiscussionReplies: 15Last Post: 14-02-2013, 07:35 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM
