02-02-2014 #11
no, its easily doable small, and compact, especially for what you need, all i meant above is you will need a water tank underneath and a suitable water pump ( £ 40 ). The other bit i say about the card and the pump, there is lots and lots of driver cards out there, when yopu have worked out what inputs and outputs you will need for your machine, then you will get good advice on what cards you need to run the motors.
At the moment, wait for one of the others to answer this
the standard sprockets should not be a problem, the more complex one, you would be better asking one of the more experiences users if they can achieve them required angles using bits, or if considerations for a B/C head strapped to the table would be the way forward from the start
02-02-2014 #12
Excellent. Thanks for your constructive reply man. Cheers
02-02-2014 #13
hmmm, sprockets and cranksets are usually forged and then cnc machining used to clean them up. they aren't machined from solid and not entirely sure why you'd want to make custom ones anyway. those could be a little ambitious. dropouts & gearhangers and lugs are probable contenders (though I'm not fully convinced about the latter)
for machining SS or titanium IMHO you'd be better off with a cnc mill rather than a router, as the key to machining hard materials accurately is rigidity but for that you will need something bigger than will fit in a 12 x 8 shed. the machine in the 'sufficiently strong' thread is very good but I'd have my doubts about its ability to machine SS or titanium. SS is 4 - 5 times harder and titanium is 2 - 3 times harder to machine than aluminium.
02-02-2014 #14
Well to be honest I don't think I will be making cranksets (it was just an idea) but sprockets for bmx and single speeds are usually made in cnc milling machines. I am not at all interested in making lugs but dropouts and gear hangers is something where I will be using this machine a lot.
02-02-2014 #15
Irvings correct when it comes to milling Titamium and even SS your into a massively differant machine to any router based machine you'll see on here.
To Mill SS or and Ti to any sort of acceptable standard you will need massive flood coolant and machine twice the ridgidty of Jonathans best effort.
Considering you have no experience of building or designing a machine then I strongly suggest you Forget the Idea for cutting this type of material because your on a hiding to nothing. Even if you gave someone like me the Challenge I'd have to sit think long and hard the best way achieve the strength you'd require and I can 100% guarantee it wouldn't be a moving Gantry router based machine.
Much better would be to buy some "Old Iron" Milling machine and retro fit it for Cnc. Still a challenge in it's self for a first timer to CNC but do-able.
If you do still want to go down the DIY build route then compleltely Forget moving Gantry style machine and look to Fixed Gantry machine. Keep the size to an absolute minimum required and build it MASSIVE strong. The larger the machine the hard that is to achive and very quickly becomes expensive has every thing has to scale up to match Ie, Motors, drives, Psu etc. It will need very good flood cooling so you will want it fully enclosed or get your self a good Mac and weelies.!!
It can be done but the machine required will be need to be several times stronger than you'll find around here and it will need someone with good engineering experience to build it accurately. You will also need Machinery to help achieve building it.
Don't think me being Negative here I'm being Honest and realistic with you.!!. . . . . . I could easily Blow smoke up your arse and say "Ye it's easy get on wi it" but I'd be a complete liar because it will be far from it.
Wish you Good luck if you do carry.Last edited by JAZZCNC; 02-02-2014 at 08:47 PM.
02-02-2014 #16
02-02-2014 #17
hi
i agree with most of what jazz says, perhaps just not the way he puts it.
now i see what you need, i would consider retrofitting a second hand industrial mill/router with cnc componants.
about what is your budget, dont be discouraged yet. i would say, second hand mill £500-£3000 ebay, cnc motors cards bits £ 500-1000.Last edited by george uk; 02-02-2014 at 09:55 PM. Reason: added
02-02-2014 #18
02-02-2014 #19
can i also add, dont get to discouraged about cutting hard material with cnc machine.
It just means slow spindle speeds/cooling and long job times, but for what your doing, that would not be a problem, you may be able to pull off what you need for around £ 1000, £ 3000 would be easyer, £ 4000/5000 you could do it without worry
Wadkin LS Router - damaged | eBay
WADKIN LS OVERHEAD PIN ROUTER 3 PHASE WORK HORSE LOTS OF PINS AND COLLETS | eBay
a good example of a cheap starting frames you could retrofit. look around, you might find one that you can gear the spindle to the right speed for you.
Then fix XY to that solid table top,
02-02-2014 #20
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
What kind of machine will do stainless steel or brass engraving
By JayPunchbuggy in forum Machine DiscussionReplies: 8Last Post: 13-03-2013, 10:40 PM -
Flexible Stainless Steel pipe that holds its shape?
By Fivetide in forum Marketplace DiscussionReplies: 15Last Post: 14-02-2013, 07:35 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM
