no, its easily doable small, and compact, especially for what you need, all i meant above is you will need a water tank underneath and a suitable water pump ( £ 40 ). The other bit i say about the card and the pump, there is lots and lots of driver cards out there, when yopu have worked out what inputs and outputs you will need for your machine, then you will get good advice on what cards you need to run the motors.
At the moment, wait for one of the others to answer this
the standard sprockets should not be a problem, the more complex one, you would be better asking one of the more experiences users if they can achieve them required angles using bits, or if considerations for a B/C head strapped to the table would be the way forward from the start
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
What kind of machine will do stainless steel or brass engraving
By JayPunchbuggy in forum Machine DiscussionReplies: 8Last Post: 13-03-2013, 10:40 PM -
Flexible Stainless Steel pipe that holds its shape?
By Fivetide in forum Marketplace DiscussionReplies: 15Last Post: 14-02-2013, 07:35 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM
