AM882 manual says this, have you tried using ProTuner ?
Standstill current setting
SW4 is used for this purpose. OFF meaning that the standstill current is software configured, and ON
meaning that standstill current is set to be the same as the selected dynamic current.
By default, the current automatically reduced to 60% of the selected dynamic current two second
after the last pulse. Theoretically, this will reduce motor heating to 36% (due to P=I2*R) of the
original value. Reduction rate and idle time can be configured in the PC software ProTuner. See
more information in section 13
8. Select configuration for different motor
There is a rotation switch to select the built-in configuration parameters for
different motor. User can select the corresponding parameter according the motor
part number. When it is 0, user can tune the parameters in the configuration
software or just activate the auto-configuration by SW4.
Holding down sheet material.
By jcb121 in forum Machine DiscussionReplies: 3Last Post: 03-07-2013, 12:11 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM -
holding mdf down to bed
By kell in forum General DiscussionReplies: 8Last Post: 13-07-2012, 02:59 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM
