Cheers Eddy, reading through the manuals, I think bumping the holding current won't change the torque in normal operation. There's a separate running current set to 100% and holding current tab set to 40%. I'm currently looking at upgrading to a bigger motor, which is an 8 wire that will be wired in series to get more torque at low speeds.
Regards,
T.
03-02-2014 #2
That's correct.
Is 240rpm the required motor speed, or shaft speed? From other threads I think it's the latter, so with the ratio you've chosen that makes the motor go at about 2.66*240=638rpm. According to the torque speed curve you've posted, the motor will only output about 2.8Nm (187 Watts) at that speed.
What I would do it make a copy of that graph in a speadsheet, by just reading off a few values and plotting them and use this to plot power vs speed. Pick the point with the highest power (which incidentally is around the corner speed) and choose your drive ratio to match that speed. To convert the torque-speed graph to power you'll need the following formula:
If the power you get using that approach is still not sufficient, that's the time to consider raising the motor voltage. Personally, for a coffe gringer I'd go for a generic motor with a planetry gearbox as it should be much more compact, efficient and cheaper.
Just to illustrate why this approach is better, one way that might seem logical is to run the motor at the speed with the highest torque output - i.e about 160rpm. So for instace 240/160=1.5 .. say 30T pulley on motor and 20T on output. That should get 7Nm at 160rpm, so 117W, which is clearly less power than the current setup so not a good way to approach this.Last edited by Jonathan; 03-02-2014 at 01:08 PM.
Holding down sheet material.
By jcb121 in forum Machine DiscussionReplies: 3Last Post: 03-07-2013, 12:11 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM -
holding mdf down to bed
By kell in forum General DiscussionReplies: 8Last Post: 13-07-2012, 02:59 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM
