Thread: How to get this finish..?
Wal Another fine job as usual but only 85% you are slipping
08-08-2016 #12
Heh, cheers Clive. Yeah, I need to work on the technique with this method - I'll get there eventually...!
Wal.
30-08-2016 #13
Finally had a bit of success using the pressure tank - it still leaks but using the compressor as a remote tank keeps it topped up for long enough to do its job. Bubbles sufficiently minimised - well , I can't see any... It's still important to prod the epoxy into the nooks and crannies - the pressure won't force the epoxy into any left-over voids in corners, as I discovered on an earlier test piece.
The MANTIS badges have been belt-sanded flush, I did attempt to polish one of 'em but the finish was rather patchy - heh - it's difficult to get a decent consistency across a larger surface using small mops on a press-drill... smaller stuff (like the skulls) come out a treat, though.
Wal.
01-02-2017 #14
02-02-2017 #15
I do quite a bit of resin filling, the resin I use is as thin as water until it sets and I have no trouble getting it in to the finest detail, I apply my resin using a dropper and a syringe for very small detail. I work mainly on glass and stone but it works equally well for metal, Can be baked in an oven as well for fast curing.
The resin is 2 part and i can adjust the opacity and colour using colourants, also get some very good effects using colours as you would a water painting.
02-02-2017 #16
Interesting - thanks for the tips guys. I've heard about flashing the epoxy with a blowtorch after pouring - not tried it as yet, but warming it up seems like a good idea. Alboy, what resin are you using? I use the stuff from Cookson Gold and it's pretty thick stuff - certainly too thick to apply via a syringe. Currently I'm using a cocktail stick and dripping the resin in off the point - and then using the point to push in to the nooks...
Wal.
Sent from my HTC One M9 using Tapatalk
edge finish - ripples and ridges
By dsc in forum Metalwork DiscussionReplies: 9Last Post: 08-07-2013, 08:53 PM -
Can you identify this paint on metal finish..?
By Wal in forum Metalwork DiscussionReplies: 2Last Post: 29-01-2013, 06:25 PM -
Better finish
By luke11cnc in forum Wood Finishing Tips & TricksReplies: 20Last Post: 27-03-2012, 11:25 PM -
RFQ: Looking for somone to finish conversion Denford Mirac with Mach3
By CHudson in forum Projects, Jobs & RequestsReplies: 0Last Post: 14-10-2010, 08:20 PM -
Need advice on surface finish
By FatFreddie in forum Machine DiscussionReplies: 4Last Post: 01-05-2010, 02:51 PM
