Page 2 of 2 FirstFirst 12
    Wal Another fine job as usual but only 85% you are slipping
    Wal's Avatar
    Heh, cheers Clive. Yeah, I need to work on the technique with this method - I'll get there eventually...!
    Wal.
    Wal's Avatar
    Finally had a bit of success using the pressure tank - it still leaks but using the compressor as a remote tank keeps it topped up for long enough to do its job. Bubbles sufficiently minimised - well , I can't see any... It's still important to prod the epoxy into the nooks and crannies - the pressure won't force the epoxy into any left-over voids in corners, as I discovered on an earlier test piece.
ID:	19104 Click image for larger version.
ID:	19105 Click image for larger version.
    The MANTIS badges have been belt-sanded flush, I did attempt to polish one of 'em but the finish was rather patchy - heh - it's difficult to get a decent consistency across a larger surface using small mops on a press-drill... smaller stuff (like the skulls) come out a treat, though.
    Wal.
    Wal.
    Hi Wal
    If you warm the epoxy up it'll get thinner and run into the corners better. Vacuum chamber would also help reduce bubbles.
    Andrew
  5. #15
    I do quite a bit of resin filling, the resin I use is as thin as water until it sets and I have no trouble getting it in to the finest detail, I apply my resin using a dropper and a syringe for very small detail. I work mainly on glass and stone but it works equally well for metal, Can be baked in an oven as well for fast curing.
    The resin is 2 part and i can adjust the opacity and colour using colourants, also get some very good effects using colours as you would a water painting.
  6. #16
    Wal's Avatar
    Quote Originally Posted by alboy View Post
    Interesting - thanks for the tips guys. I've heard about flashing the epoxy with a blowtorch after pouring - not tried it as yet, but warming it up seems like a good idea. Alboy, what resin are you using? I use the stuff from Cookson Gold and it's pretty thick stuff - certainly too thick to apply via a syringe. Currently I'm using a cocktail stick and dripping the resin in off the point - and then using the point to push in to the nooks...
    Wal.
    Sent from my HTC One M9 using Tapatalk
  1. edge finish - ripples and ridges
    By dsc in forum Metalwork Discussion
    Last Post: 08-07-2013, 08:53 PM
  2. Can you identify this paint on metal finish..?
    By Wal in forum Metalwork Discussion
    Last Post: 29-01-2013, 06:25 PM
  3. Better finish
    By luke11cnc in forum Wood Finishing Tips & Tricks
    Last Post: 27-03-2012, 11:25 PM
  4. RFQ: Looking for somone to finish conversion Denford Mirac with Mach3
    By CHudson in forum Projects, Jobs & Requests
    Last Post: 14-10-2010, 08:20 PM
  5. Need advice on surface finish
    By FatFreddie in forum Machine Discussion
    Last Post: 01-05-2010, 02:51 PM
