Thread: CW8060 or alternative?
I am currently using 2x CW8060 drivers on my Y axis (long) and a singe 2M542 driver on the X (width) axis.
I think this is probably limiting my cutting speed, so I want to put a CW8060 on the X axis too. They don't seem so readily available as they were 2 years ago, so is it best to search one out, or just use an alternative (now better) model?
If someone has a CW8060 to sell cheaply, please contact me!
03-02-2014 #2Spelling mistakes are not intentional, I only seem to see them some time after I've posted
03-02-2014 #3
Thanks. I found that too but I was hoping to get used a little cheaper ;)
03-02-2014 #4
If I recall correctly you're using 3Nm motors, so the phase current is 4.2A? If so then there are plenty of drivers to choose from - DQ860MA is generally a cheap one that works well.
What speed are you getting on X and Y? How much different are they?
03-02-2014 #5
I've got 4Nm motors on all axis.
Difficult to say about speed exactly. I was using a max of 7m/min mostly just doing rapids. I found there were sometimes missing steps and position was slightly lost. I dropped that down to 5m/min and it worked better. Still I don't cut faster than 4m/min or things like sharp corners become rounded.
What are the differences between DQ860MA and CW8060? They looks about identical.Last edited by Tenson; 03-02-2014 at 07:57 PM.
Heidenhain ME 101 Tape reader or alternative program storage.
By corkcnc in forum Machine Control SoftwareReplies: 3Last Post: 19-03-2014, 11:28 AM -
Alternative slides and guides
By Swarfing in forum Rails, Guideways & BearingsReplies: 14Last Post: 23-04-2012, 07:14 PM -
AutoEditNC alternative?
By DanielF in forum Programmers CornerReplies: 12Last Post: 22-02-2012, 12:46 PM -
Cheap Sign Foam Alternative
By action-kat in forum Machine DiscussionReplies: 5Last Post: 20-09-2011, 12:35 PM
