Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yep, good point..! Something like these, perhaps?
    TP-Link 200Mbps Powerline Pass-Through Adapter - Twin.. | Ebuyer.com
    Could get internet on my telly then, as well...
    Wal.
    Wal Yes they will work, you can also get them with say 2 or 4 lan ports out and even with one as an AP point. But be aware that they are not all compatible with each other. ..Clive
    Thank you for the reposes guys, i,ll be looking into them later today. Thanks again.
  3. Slightly OT - Been using the Solwise 200AV homeplugs for a couple of years and rock solid. Streaming video from network drive to tv is great :)
    Words of advice :
    - don't mix n match supplier, it should work but pita.
    - make sure all devices use the INT64xx chipset and not the cheaper QCA one else video streaming is comprised.
    - use piggyback ones where possible, it saves hassle with extension leads and getting enough sockets
    - don't bother with 500AV, it's no faster unless your mains wiring is top notch and short, esp if you have multiple rings.
    Solwise are a good company I have used them for many years. I have used these in the past Solwise HomePlug AV with 4 Ethernet Ports - PL-200AV-4PE and Solwise HomePlug AV with 4 Ethernet Ports - PL-200AV-4PE together the first has 4 sockets and the second 2 sockets but it includes wifi as well. They also have a pair which is good value Solwise HomePlug AV Push Button SecureSync - NET-PL-200-AV-TWIN for about £25 .. Clive
  5. #15
    Wal's Avatar
    Irving, Clive - thank you both kindly for your advice. Solwise it is!
    Wal.
  1. Some Gcode generating programs
    By Jonathan in forum Programmers Corner
    Last Post: 28-02-2014, 07:58 AM
  2. WANTED: Van ply lining programs
    By vehicle accessories in forum Items Wanted
    Last Post: 31-08-2013, 12:34 PM
  3. Examples Heidenhain programs with drawings
    By hoezap in forum Computer Software
    Last Post: 09-02-2013, 12:54 AM
