07-02-2014 #16
Again the Ganrty looks quite weak but more than that it use's V bearings, which are basicly just fancy skate board bearings, and pressed steel for Linear motion which isn't very good in my experience.
Problem comes from fine dust building up on the rails and collecting on the bearings which can lead to stalling motors etc if not kept clean. Even with good dust extraction I wouldn't use them has there will be wear issues with the thin Steel sheet which will mean regular adjustment.
When cutting wood, MDf etc dust it will be bad enough but with plastics it will be even worse has the static makes it stick to everything. If you look at the video you can see it starting to build up at the sides and you'll see they have built make shift barriers to contain the dust.
The linear motion is such an important area of a machine that cost cutting in this area always leads to regret in my experience. Company's do it to maximise Profit. DIY builders do it to keep costs down but it makes for a much poorer machine which ever reason.!!
Help on a couple of "niggles" with my machine.
By Washout in forum Machine DiscussionReplies: 4Last Post: 24-04-2014, 12:30 AM -
Now that's what ya call a "BIG" CNC machine.!!
By JAZZCNC in forum General DiscussionReplies: 7Last Post: 08-04-2014, 11:25 PM -
BUILD LOG: My baby 15" x 15" machine
By wilfy in forum DIY Router Build LogsReplies: 129Last Post: 19-03-2013, 09:16 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
Calibrating my new machine - "never the same twice" woes
By HankMcSpank in forum General DiscussionReplies: 4Last Post: 23-11-2011, 05:54 PM
