  1. Quote Originally Posted by JAZZCNC View Post
    This machine is very flimsy in some important areas.!
    Basicly it looks like a Aluminium profile frame work with Slotted profile for the bed sat on pressed steel tressels. The gantry sides are very flimsy pressed steel and don't look very well braced or supported where they meet the linear bearings.
    It also use's rack & pinion for the long axis which isn't unusual for this size machine but it doesn't look to have much gear reduction so could be low resolution.? Also the torque could be low with those smaller Nema 23 motors with no or low reduction.
    The Z axis is very poor design and use's unsupported round rail with only 2 bearings and a flimsy front plate which spindle attaches to. The spindle is actually an Ok spindle which is similair to the Kress but better with more power. German made I think.?
    Being honest you are paying mostly for the T-slot the bed which at this size machine is very expensive but it's failing in some very important places like Z axis and Gantry strength. In practice for mostly wood based machine then T-slot isn't worth the expense IMO and just a simple stable material for the bed with a MDF spoil board is much better and far cheaper.
    Not sure you could buy a cheaper or better machine from any other Company at this size but you certainly could build one far far better for less than 5K.
    IMO it would be a bad move to buy this machine has it will yield only average results and lower quality finish.
    Thank you very much for all the info.
    You said something that got in my mind... that making one myself i would be better served.
    Do you think this is an easy job? As you can see by my presentation:http://www.mycncuk.com/forums/new-me...html#post54728
    Im not afraid of the construction itself. In fact i can make any thing in metal/steel from a 3d Model, almost without paying for it. What worries me is the servos and the mechanic of the thing. I have assembled a Ultimaker, and done a electric bycicle:
    But all this was done by following simple instructions and searching the web.
    BUT I LOVE THE IDEA OF BUILDING IT! HAHAHAHA
    Do you recomend any "Bible" for the job?
    Thanks again
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    You're reading it. ..Clive
  3. Quote Originally Posted by Clive S View Post
    "Here i go!"
  1. Help on a couple of "niggles" with my machine.
    By Washout in forum Machine Discussion
    Last Post: 24-04-2014, 12:30 AM
  2. Now that's what ya call a "BIG" CNC machine.!!
    By JAZZCNC in forum General Discussion
    Last Post: 08-04-2014, 11:25 PM
  3. BUILD LOG: My baby 15" x 15" machine
    By wilfy in forum DIY Router Build Logs
    Last Post: 19-03-2013, 09:16 PM
  4. "Racks" VS "ball screw"
  5. Calibrating my new machine - "never the same twice" woes
    Last Post: 23-11-2011, 05:54 PM
