    I know when I use my plasma, I can get away with working on top of a sheet of metal with the clamp attached, and don't have any issues.
    Could you clarify that a bit, are you saying your table is a sheet of metal that is connected to plasma ground or something else?
    one of my reasons for angle would be that they are self supporting so I would only need a few for small work and can be moved about easily, will look into strips too.
    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I only use my plasma manually, but have at times just clamped the earth to whatever sheet I've just cut the end of, then recut bits on top of that sheet. I've never had any issues with it not starting, but then mine has a high frequency/pilot arc start, so may be more tolerant of a less than ideal ground.
  1. Connection the plasma cutter to the CNC machine?
    By gr8fun in forum Plasma Table Machines
    Last Post: 22-05-2014, 10:49 AM
  2. FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
    By nobby in forum Items For Sale
    Last Post: 20-05-2014, 07:33 PM
  3. Replies: 0
  4. Portable CNC flame plasma cutting machine
    By WandrinAndy in forum Machine Discussion
    Last Post: 03-09-2013, 04:09 AM
  5. CNC milling machine full support required
    By Rebekah_harper in forum Milling Machines, Builds & Conversions
    Last Post: 26-05-2012, 10:57 PM
