I used to cut the foam (V28 is the grey stuff you're in about) for DFS sofas and we used big (52" of exposed blade) band knives with moving tables. We had a CNC machine for cutting out shapes and that again was a band knife (Fecken Kirfel was the make, or spelt something like that) but with 6 steppers to drive the blade and twist it. If you try to use a simple blade then as soon as it gets blunt (which it will quickly) it will tear the foam. You'll be better with a reciprocating blade or a band knife and moving/swivelling table.
laser cutter/engraver rebuild build log
By gavztheouch in forum Laser Machines & BuildingReplies: 37Last Post: 10-11-2015, 05:37 PM -
Hand held laser cutter
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 9Last Post: 24-10-2013, 06:05 PM -
What wattage laser cutter question
By Fivetide in forum Laser Machines & BuildingReplies: 9Last Post: 09-08-2013, 02:56 PM -
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
