    This is really at the spec stage. I'm still reading my way through the logs here so just filling out information as I go, but any early feedback much appreciated. Once we've got a spec settled, I'll start CADing up the design. There are a lot of "spec?" questions below, as I can't really find super-clear answers (perhaps I'm looking in the wrong place). Also: I think I've covered all the categories... but have I?!
    D O R I S C N C
    By WoodSpiral and CB
    Cutting envelope: 2m x 1m x 0.2m
    Application: Light commercial for cutting wood.
    BASE
    - 50x50x3mm box section mild steel, welded.
    OR
    - Bolted steel/extruded sections?
    OR
    - Plywood + 2x4's
    EXTRUSIONS
    Aluminium Profile Series 6
    OR
    KJN Aluminium profile
    RAILS + RUNNERS
    - Should be supported along their length.
    - spec?
    PSU
    - spec?
    DUST EXTRACTION
    - Something like: Split Dust Shoe, KentCNC, Dust Shoe Demo - YouTube
    MOTORS
    - If gantry >80kg, need servo motors not steppers.
    SPINDLE
    - spec?
    SPINDLE HOLDER
    - will follow from spindle choice.
    SCREW THREADS
    - Speedy High-Helix Lead Screws (?)
    GANTRY & Z CONTROL
    CONTROLLER
    - spec?
    SOFTWARE
    - Sketchup / Rhino / AutoCAD
    - TurboCNC
    GENERAL SUPPLIERS
    CNC4YOU for your CNC Parts and Spares CNC Machines DIY CNC Hobby CNC Router Lathe Milling
    Zapp Automation Ltd
    OTHER NOTABLE BUILDS
    http://www.mycncuk.com/forums/router...rst-build.html
    Useful sites for info
    https://www.buildyourcnc.com/
    Links
    Thanks,
    Woodspiral.
    Ok I'll make this bit easier for you and tell you specs that I know work for this size and type machine.
    Base frame: 50x50 or 60x60 x 3 or 4mm Steel. (Forget Ply wood waste of time)
    Gantry: Steel or Alu profile.
    Z axis: 20mm thick Aluminium no less.
    Rails: Ideally Profiled Linear rail 15 or 20mm. At Minimum 16mm round supported rail.
    Ballscrews: X & Y axis(upto max 1500mm length) 16mm dia 10mm pitch (Above 1500mm) 20mm Dia 10mm pitch.
    Z Axis 16mm Dia 5mm pitch.
    Motors: 3.1 or 4Nm Nema 23 on All axis. ( Twin Slaved motors on Long Axis)
    Drives: 75-80Vdc ideally good quality Digital drives Like Leadshine AM882 or EM806.
    Main PSU for drives: 65-70Vdc Un-regulated with Amp rating aprox 70% of total number of motors rated Amps Ie: 4 x 4.2A motors =16.8/80%=11.5A
    Secondary PSU for E-stop, limits etc: 12 or 24Vdc 3-5A switch mode.
    Breakout board(BOB): Good quality not cheap rubbish. PMDX 126 is only one I'll fully recommend but others Like DIYCNC OPPB V3 can be Ok.
    Cable: Shielded cable for Motors and Limits/E-stop switches.
    Spindle: 2.2Kw water cooled Spindle and VFD is best value for money spindle you'll find, nothing else comes close.
    Control Software: Mach3 or Linux cnc. Mach3 has the best support for new users and is easy to setup. Linux cnc don't use so won't comment.
    Cam software: Mostly Dependant on use but Vectric or Delcam software for mainly wood use, Cambam is good free/cheap software.
    Suppliers are many but word of advise is to buy ballscrews and linear rails, spindle from China has they are cheap. All electronics Drives, motors etc from Uk or states(pmdx) for warrenty reasons and ease of replacement.
    Good luck and keep reading and asking if unsure.
  3. The Following 4 Users Say Thank You to JAZZCNC For This Useful Post:
    I would try and squeeze your cutting envelope to at least 1.2m by 2m so you will be able to cut full sheets of ply.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  5. #4
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    ...and that's probably the most succinct but relevant post on the forum! At least, for anyone looking to build roughly this size machine. It's taken me about a month of trawling the forum to come to pretty much the same results that Jazz has given. I'm looking at a cutting envelope of around 1300x700 so that I can comfortably machine the outside of a quarter-sheet of panel material.
    You might try to skimp on the spindle as you're unlikely to need that power. Don't, because what the 2.2KW spindle gives that the next size down doesn't (and for not a great deal more money) is an ER20 collet which will take up to 1/2" shank cutters. That can be really useful.
  6. #5
    Jazz, that's brilliant thank you. I'll work these specs into the plan. Hopefully the next iteration will have more detail and approximate prices. Then I can flesh out with drawings.
    Gav, don't you mean 1.2 x 2.4m ? Could go for that big... but I'm not necessarily thinking of feeding whole sheets in for mass manufactured items. When I said light commericial it is likely to be bespoke projects, but I do see your line of thinking and it is worth considering.
    Neale, yep appreciate that; 1/2 cutter shanks are man enough.
  7. #6
    "Gav, don't you mean 1.2 x 2.4m ? Could go for that big... but I'm not necessarily thinking of feeding whole sheets in for mass manufactured items. When I said light commericial it is likely to be bespoke projects, but I do see your line of thinking and it is worth considering."
    Sorry yes 1.2 by 2.4m or you could go for 5 foot by 10 foot if your feeling brave.
    ADD ME ON FACEBOOKS
  8. The Following User Says Thank You to gavztheouch For This Useful Post:
  9. #7
    Quote Originally Posted by gavztheouch View Post
    Wouldn't Recommend going this large for first time machine has going large introduces more complexitys. At this size you'll be into Rack & pinion with belt reduction and larger motors, drives, psu etc.
    Instead of working to full sheet sizes then work to half or better still quarter sheet size for a First time machine has you'll find it much easier to build.
  10. #8
    It's been a while, and we've made no physical progress with this project, but we have come up with some ideas.
    I've been watching Dave Gatton's CNC project on YouTube and it seems pretty impressive for the cost and ease of build. I've also got hold of his plans which seem pretty straightforward. TBH I think this is a quick project to get us started here, to learn about the process with low costs. I know it's a plywood based project, but given the design I think it would be very stable - the gantry looks like it wouldn't move any. Correct me if I'm wrong. If nothing else we could use it to cut parts for a aluminium-based model, and rebuild it!
    He also recommends a company called Xylotex for the drive + psu + 3 motors (and possibly the BOB too), which come all told to $325 all ready to go. Too good to be true?
    'Spiral.
  11. In a nutshell, yes. You can get it cheaper on eBay. But what you get is very low spec. and will be throwaway kit when you upgrade.
    It's a one board solution including the bob so when it fries as these are regularly known to do it's a replace it all job. Search for TB6600 and TB6560 on the forum to see why these are not a good idea.
    Sent from my HTC One_M8 using Tapatalk
  12. #10
    I currently use an MDF router to the free JGRO design - there's plenty of info around about it. I built it a couple of years back, and have used it a fair bit. MDF is probably not as stable as ply, to be fair, but it has a number of limitations. It isn't very strong, which really restricts cutting speeds which are painfully slow. In an unheated garage, it isn't very stable which means that particularly bed alignment varies so depth of cut is difficult to maintain across the bed. It is difficult to maintain bearing alignment, so you are continually adjusting. I use threaded rod as leadscrews which gives slow speeds due to whip. You could fit decent bearing rails although bed distortion would make those difficult to keep aligned; ballscrews would give better speeds but the bed structure couldn't take the cutting loads. In any case, by the time you have bought decent bearings/ballscrews, the cost of the structure is a small part of the total. It's been great as a starter project where all but motors and electronics are considered throwaway but does the fact that I'm building a steel router now tell you anything?
    Rather than look to the US, take a look at cnc4you, Zapp Automation, or other UK sources if you don't want to go to China.
  1. Feedback
    By Jester in forum Stepper & Servo Motors
    Last Post: 02-02-2014, 03:49 PM
  2. Help appreciated
    By joncdrl in forum Milling Machines, Builds & Conversions
    Last Post: 17-09-2012, 08:34 PM
  3. RFQ: Early enquiry
    By boldford in forum Projects, Jobs & Requests
    Last Post: 30-07-2012, 06:40 PM
  4. Strong 1212ds - any advice greatly appreciated!
    By MrWiz73 in forum General Discussion
    Last Post: 30-03-2011, 05:17 PM
  5. NEW MEMBER: early stages
    By dopamine in forum New Member Introductions
    Last Post: 04-12-2010, 01:33 PM
