Thread: Create dxf file.
To avoid the double lines in Illustrator, in Tracing Options : turn off fills, turn on strokes and change 'max stroke weight' to 100px.
You will probably have to combine this output with the text you traced using the default settings.
HTH,
Si.Last edited by firetrappe; 09-02-2014 at 11:39 PM.
The Following User Says Thank You to firetrappe For This Useful Post:
10-02-2014 #2
I must admit that I would like to find some decent software (even if it is a bit expensive) that will give a fairly clean vector drawing from bitmap/jpeg to DXF. I have posted this request some time ago, but the usual "freebies" Inkscape etc. just do not seem to work too well for me. I have considered trying a diditizing tablet - does anybody use that method? Thanks in anticipation of any suggestions. G.
10-02-2014 #3
Geoffrey, wouldn't that just be great, even better if it was freeware. LOL
I met a guy on Facebook, a great artist in drawing, he uses a digitizing tablet with a program called XARA and turns out some great work with it.
My son bought me one a few years ago but I could never get the hang of the thing, mind you must be about 10-12 years ago so maybe the newer ones are a lot better.Last edited by Tanky_Turk; 10-02-2014 at 06:47 PM.
10-02-2014 #4
Thanks mate, that did the trick.
I made a new psd file and separated the "graphics" and "text" in two different layers. I then opened the psd file and traced each part indivudually as you suggested. The "graphic" trace looks (almost) perfect now, just got to play around with the other setting to see if I can get a better trace.
The only other problem I have now is that the dxf file is massive, about 38MB, takes ages to open and work on in CAMBAM.
Is there any way to make it smaller without losing quality?
Thanks for your help.
Eric
Solidworks file help
By D-man in forum SolidworksReplies: 4Last Post: 19-08-2013, 01:03 AM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
Plasma file problem?
By D-man in forum Computer SoftwareReplies: 9Last Post: 27-07-2012, 08:43 AM -
File sharing
By cgw59 in forum General DiscussionReplies: 7Last Post: 02-07-2010, 07:53 AM
