10-02-2014 #1
Linear profile rails have torque recommendations for the fasteners used -from what I've seen, something akin to what a grade 10.9 may be torqued up to. Also, there are recommendations on the thickness of the material being bolted into - usually typically the depth being equal to the depth of the rail being used. The depth of the supporting material obviously adds stiffness, but is also required for thread engagement and a factor of safety on stripping at the recommended torque tightening values. I've got the impression folks drill and tap as low as 3mm thickness on square hollow section and drill and tap to fasten linear profile rail to it, which by the numbers I've briefly looked at is nowhere near enough for grade 10.9 type torques. Do people here do any numbers / calc's for the permissible torque values for fasteners in such scenarios?
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
FOR SALE: Round linear rail and bearings
By routercnc in forum Items For SaleReplies: 5Last Post: 19-08-2010, 05:17 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
