Page 10 of 29 FirstFirst ... 8910111220 ... LastLast
  1. #91
    Quote Originally Posted by charlieuk View Post
    what are the best methods for tensioning timing belts on to steppers. I have slots for adjustment but need some sort of screw type adjuster to get the belt relatively tight. Cant seam to find much on here.
    Section 10 page 45.
    http://file.lasersaur.com/docs-third...ming_Belts.pdf
    I just used the same technique as putting an alternator belt on, stick a large screwdriver in behind the motor and lever it out until the belt is at the 'correct' tension, now tighten the bolts.
  2. #92
    i guess that keeps things simple! the pulleys i have have two grub screws for securing however the shaft is totaly round, whats best to do there? put a flat for them or drill a hole or something? cheers charlie
  3. #93
    Use two grub srews M4 will do, these MUST be 90 degrees apart around the pulley boss (i.e. NOT opposite each other). File a small flat on the motor shaft for one of these screws only. Where the flat is, use a flat bottom grub screw, for the other screw grind it to a point so it digs into the shaft once tightened.
  4. #94
    cheers many thanks thats great will get on to that
  5. #95
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The way I have done mine is to put a copper plug (pad) into the grub screw hole. I have done this by using a bit of solid core earth wire from twin&earth cable just lightly swash it with a hammer and then cut a piece off that will fit down the hole so that the flat bit is on the shaft then just tighten the grub screws. That way you don't mark the shaft.
    I have found that it is not necessary to put a flat on the motor shaft. ..Clive
  6. #96
    Im sure the locknuts for my ball screw BK blocks had a grub screw arrangement like that.
  7. #97
    Yes all mine did as well it's a common way of fixing as it does not damaged the shafts so that makes them easy to remove later if necessary. ..Clive
  8. #98
    belts arrived, i had to go with 5 teeth less on the motors to get it to fit unfortunately well unless the belts stretch a fraction as it is right between sizes.
  9. #99
    I mentioned it in a post earlier that i am geting a small amount of flex from the main back uprights which for the surfboards really isn't a problem as the load on the machine will be close to nothing cutting foam however i would like to try and reduce it as much as posable. I have been wondering about two options the first being bolting a pice of 90deg angle steel to each leg ( i cant get large enough channel or T section) and the second idea was to fill each of the current aluminium legs with a resin/granite mix or maybe even a concrete mix which i have been reading about which may help in other ways as well.
    Can any one give any suggestions as to what may be best?
    many thanks
  10. #100
    any one got any ideas to the above?
  1. RFQ: Does anyone want to build me a cnc router?
    By totally useless in forum Projects, Jobs & Requests
    Last Post: 08-05-2014, 09:55 PM
  2. Does anyone want to build me a cnc router?
  3. How Not To Build A Router
    By Clive S in forum Gantry/Router Machines & Building
    Last Post: 17-11-2013, 10:09 AM
  4. BUILD LOG: CNC Router New Build
  5. BUILD LOG: A3 Router Build
