Thread: Giant 20' x 3' x 2' router build
Been playing about with a few bits like mounting the screen to the wall , putting the vfd screen on the out side of the box and also found a good use for round rail supports to make nice solid simple mounts for the proximity switches over my slightly crude aloy boxes.
29-10-2014 #2
I'm having a few problems with my home and limit switches, I had a similar problem the last week but managed to sort it by adjusting it through the input signal filters in the csmio plug in however now I can't find the happy medium I found last time the video should explain the rest.
29-10-2014 #3
Charlie are you using shielded wire for the cable back to control box and is the sheild earthed just one end inside the control box.?
Also is the machine frame earthed to same earth point.?
You have long wire runs so they will act like antenna picking up any noise so you'll need to Eliminate this really before you'll get any joy.
I would also try a differant switch you maybe have poor switch with slow components giving slow reaction times.?
29-10-2014 #4
What do you have debounce set to in Mach3 General Config ?
29-10-2014 #5
29-10-2014 #6
29-10-2014 #7
29-10-2014 #8
Yes it's all shielded at one end the Ali frame is directly bolted to the floor the moving part of the gantry though may not have any sort of ground unless it can travel through the Hiwincarriages. The problem seams to effect all switches. I was wondering about replacing a switch but wire it straight to the csmio ? Would it be best to disconnect the rest of them if I did that?
29-10-2014 #9
29-10-2014 #10
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
