Thread: Giant 20' x 3' x 2' router build
31-10-2014 #11
Did it have a hole in the middle like the cap head screw or was it solid metal right across and at least the same diameter as the proximity switch ?
This is from Baumer inductive sensors catalogue.
Baumer
"Maximum cable length A large cable length is a capacitive load for the output circuit and increases the influence of interference. Length should therefore be kept as short as possible."
They don't quote a figure for max length though.
This is why I suggested using single core bits of wire just as a test over the distance, the capacitance is going to be low if they are kept well apart.
Save yourself the grief and fit mechanical switches for limits, you won't have these problems then.Last edited by EddyCurrent; 31-10-2014 at 11:14 AM.
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
