Thread: Giant 20' x 3' x 2' router build
14-11-2014 #26
when i started with mach3 i also found this rather unusual , that the machine wouldnt return to the point where i stopped it
but when you start to read G code and start to understand what i means, then it all starts to make sense
for example , when cutting an arc ( as mentioned ) and you stop the machine lets say 1/4 of the way thru the arc , when you restart , it will not resume from that 1/4 point thru the arc ... it will either start at the beginning of the arc , or the next line of G-code
the same with height, z - axis ... if im doing a cut , stop mid way thru and then RAISE the machine ... when i restart , the machine doesnt know that it been raised , and will only change the height when a line of gcode tells it to , so you may do an air cut for a few lines of code depending on what you cutting ....
if i stop and want to continue , i rewind a couple lines of code ...
and yes , you need to start the spindle manually ( again g code tells spindle to start right at the beginning of the code )
keep at it and it all starts to make sense .... :)
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
