Thread: Giant 20' x 3' x 2' router build
what are the best methods for tensioning timing belts on to steppers. I have slots for adjustment but need some sort of screw type adjuster to get the belt relatively tight. Cant seam to find much on here.
07-08-2014 #2
Section 10 page 45.
http://file.lasersaur.com/docs-third...ming_Belts.pdf
I just used the same technique as putting an alternator belt on, stick a large screwdriver in behind the motor and lever it out until the belt is at the 'correct' tension, now tighten the bolts.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
08-08-2014 #3
i guess that keeps things simple! the pulleys i have have two grub screws for securing however the shaft is totaly round, whats best to do there? put a flat for them or drill a hole or something? cheers charlie
08-08-2014 #4
Use two grub srews M4 will do, these MUST be 90 degrees apart around the pulley boss (i.e. NOT opposite each other). File a small flat on the motor shaft for one of these screws only. Where the flat is, use a flat bottom grub screw, for the other screw grind it to a point so it digs into the shaft once tightened.
08-08-2014 #5
cheers many thanks thats great will get on to that
08-08-2014 #6
The way I have done mine is to put a copper plug (pad) into the grub screw hole. I have done this by using a bit of solid core earth wire from twin&earth cable just lightly swash it with a hammer and then cut a piece off that will fit down the hole so that the flat bit is on the shaft then just tighten the grub screws. That way you don't mark the shaft.
I have found that it is not necessary to put a flat on the motor shaft. ..Clive
08-08-2014 #7
08-08-2014 #8
12-08-2014 #9
belts arrived, i had to go with 5 teeth less on the motors to get it to fit unfortunately well unless the belts stretch a fraction as it is right between sizes.
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
