Thread: Giant 20' x 3' x 2' router build
05-05-2014 #10
No real standard way regards laying out as it's often machine dependant but regards sizes etc then there is kind of standard in that most use in HTD 5mm pitch belts and either 15 or 25mm wide. Pulley sizes will depend on if your having a ratio but from experience between 18-20T for 1:1 ratio is best. If you go too small you risk excessive wear and jumping teeth due to fewer teeth being engaged. Equally don't go too large on pulley size as the extra inertia will have a negative affect.
Really this is something you should have worked out before ordering the ballscrews as you could have had the screws machined in such away that they suited pulleys and made life easier.
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
