Thread: Giant 20' x 3' x 2' router build
The way I have done mine is to put a copper plug (pad) into the grub screw hole. I have done this by using a bit of solid core earth wire from twin&earth cable just lightly swash it with a hammer and then cut a piece off that will fit down the hole so that the flat bit is on the shaft then just tighten the grub screws. That way you don't mark the shaft.
I have found that it is not necessary to put a flat on the motor shaft. ..Clive
08-08-2014 #2
08-08-2014 #3
12-08-2014 #4
belts arrived, i had to go with 5 teeth less on the motors to get it to fit unfortunately well unless the belts stretch a fraction as it is right between sizes.
13-08-2014 #5
I mentioned it in a post earlier that i am geting a small amount of flex from the main back uprights which for the surfboards really isn't a problem as the load on the machine will be close to nothing cutting foam however i would like to try and reduce it as much as posable. I have been wondering about two options the first being bolting a pice of 90deg angle steel to each leg ( i cant get large enough channel or T section) and the second idea was to fill each of the current aluminium legs with a resin/granite mix or maybe even a concrete mix which i have been reading about which may help in other ways as well.
Can any one give any suggestions as to what may be best?
many thanks
13-08-2014 #6
any one got any ideas to the above?
13-08-2014 #7
Just a thought could you not bracket them to the wall? ..Clive
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
