Thread: Giant 20' x 3' x 2' router build
29-10-2014 #161
29-10-2014 #162
29-10-2014 #163
29-10-2014 #164
29-10-2014 #165
Had a feeling that was the case jazz
thanks guys will do that and report back voltage at the switch is 23.9/24v
29-10-2014 #166
Thinking about it then I really need to earth each of the axis? If so can I earth the z to the y then y to the main frame then back to the control box ?
29-10-2014 #167
30-10-2014 #168
I have now earthed every thing together and it seams to have improved it in that the filter can now be set a lot lower however I still have the same problem. I did all so find one ferrite ring I put onto one of the signal wires at the control unit end but that didn't make any notable difference. What the best next step to take try some better switches?
30-10-2014 #169
Set up the soft limits and slow zones, section 10.8 of csmio manual I'm looking at.
Mach3 General Config, try 'Home SW.Safety' in both states to see what happens.
Follow csmio manual section 10.11 and go through Mach 3 settings as shown.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
30-10-2014 #170
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
