Thread: Giant 20' x 3' x 2' router build
31-10-2014 #11
No not really got it wrong at all.! Have you considered Your Conclusion is wrong.? Swapping for MS is masking the issue has the capacitance is still there and needs dealing with rather than avoiding (masking). Charlie as tried different cable and it's still there, was worse actually, yes could still be capacitance but I don't think so at only 12mtr length and 24Vdc. But my conclusion could be wrong also.?
The home switches are not Ok even at homing speeds this has been tried.! Also how can they be trusted if we haven't conclusively found the cause.?
Your method while yes maybe getting the machine working isn't the correct one IMO. It's still a mask for the real cause and who's to say this cause isn't going affect other aspects of the machine later down the line.? . . . .What if it is a wiring or grounding issue that isn't found now but surfaces at a later date when newness wears off or other attachments get added like probes etc which could suffer from same issue.?
Best resolved now and after all obvious causes have been eliminated then the next logical choice is to replace suspect components for same type or like in this case with same type but being of better quality. Changing to a compleltely diffeant switch type will in this case potentially mask some other cause or fault.!
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
