300mm by 300mm would be optimum but 150*150mm would likely be enough.
I like the look of this epoxy granite machine.
https://www.youtube.com/watch?v=84iP10KShvYCNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
10-02-2014 #2
Yes I was going to suggest Epoxy Resin and have looked at my self few times and some where I've even drawn the Moulds up in Solid works.
For a small precision machine this would be the way I would go 100% sure of it.
One thing I did look at doing and I think would make for a very accurate and easy build for a small machine is buying 2 600x600x100 Granite surface blocks which are very accurate. One for the Base which would have rails and ballscrews directly mounted on it.
The other I would stand vertical and cut centre out for clearence and mount rails/ballscrews on front. Then Would bolt the two together and make a Stiff supporting frame work from steel which would be used for alignment and setup and securely fastend to both. This frame work would then be surround by mould and Epoxy granite Resin poured into to give a very accurtate and stiff vibration damping chassis. (Think Concrete and Re-Bar type thing.!!)Last edited by JAZZCNC; 10-02-2014 at 10:30 PM.
Soft Start Advice
By GTJim in forum General ElectronicsReplies: 18Last Post: 15-01-2015, 08:47 AM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
Tooling
By p1lts in forum Tool & Tooling TechnologyReplies: 9Last Post: 11-10-2011, 08:14 PM -
HSK Tooling
By Dairsie in forum Tool & Tooling TechnologyReplies: 3Last Post: 02-09-2011, 10:07 PM -
Scrool jaw ring for hydraulic soft jaws.
By Pmac in forum Tool & Tooling TechnologyReplies: 4Last Post: 28-01-2010, 07:55 PM
