Thread: stiffness measurements cnc mk3
The rpm I use is around 12000 (200Hz). If I put the following into that calculator:
6061 T6 aluminum
solid end mill, carbide
6mm 2 flute
DOC1 mm
WOC 6mm
slot/pocket = yes
SFM, FEED 100%
max rpm 12000
I get a feedrate of 900mm/min. I'll keep experimenting with the next parts I cut out to see if I can get a better finish.
27-04-2014 #2
600mm/min @ 12000rpm generally works well with a single flute cutter, so since one would expect the chipload to be slightly lower for a 2 flute cutter, as a first approximation the feedrate should be a little less than 1200mm/min.
What are you mounting the workpiece on? It can make a big difference to the finish - for example I found it easier to get a good finish when taking a small cut with my machine when it had the MDF bed. Presumably the MDF's damping properties helped. If the parts are small you'll obviously have problems with rigidity using MDF, but if they're a reasonable size and you add a finishing pass (take off 0.1-0.2mm from edge in one pass) you can get good results, e.g:
(20mm thick parts and 25mm thick bed)
I've still not measured, but I'm pretty sure your machine is stronger than my 'old' one which cut the parts above (and below), so unless you have big problems with resonance you should be able to get similar results. Perhaps MDF is worth a shot? That's not to say you can't get a good finished clamping rigidly to aluminium, it just takes a bit more care/luck setting the feedrates, e.g:
cnc machine stiffness calculator
By routercnc in forum Linear & Rotary MotionReplies: 13Last Post: 02-09-2022, 04:32 PM
