13-02-2014 #11
That's far too general and you can't say "Best Speed" because there is no "one" best speed for cutting aluminium there are far to many factors come into play which determine the speed.!! . . . . Material grade, cutter size, No flutes, DOC, Cut type ie: slot or side cutting, step over, coolant type . . . .And thats before you get into Spindle power and machine strength.
Can tell thou 100% There is no ONE speed does all and you'll fluctuate between 7-15K when cutting ALi with 4-10mm tooling with varying no of flutes and DOC & S/F etc.
Experiment is the best way to learn speeds & feeds and dont be affraid to cut deep, just be prepared and accept that you will break tools while finding the best cutting conditions for your machine and material.Last edited by JAZZCNC; 13-02-2014 at 04:36 PM.
aluminium machining
By drumsticksplinter in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 15-03-2013, 12:19 AM -
RFQ: Aluminium frame Machining
By mZeles in forum Projects, Jobs & RequestsReplies: 4Last Post: 27-12-2012, 08:17 PM -
Machining Aluminium
By Steff in forum Metalwork DiscussionReplies: 7Last Post: 14-11-2012, 12:48 PM -
Breaking cutters machining aluminium
By ukpete in forum Tool & Tooling TechnologyReplies: 10Last Post: 16-08-2011, 07:23 AM -
Aluminium Kress Spindle Holder
By Lee Roberts in forum Metalwork Project ShowcaseReplies: 12Last Post: 16-07-2009, 12:00 AM
