Page 3 of 3 FirstFirst 123
  1. #21
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I was getting all excited (sad I know!) about adding a 3D print head to my router (when I finish it...) and then I remembered that I'll be mounting it nearly vertically....doh! Ok so I'll have to make a second CNC machine :)
    You can use a 3d printer upside down if you want. ,,Clive
  2. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  3. #22
    Im no expert as I haven't even hot the bits yet but I'd be fairly certain a 3d printer does not care about orientation due to the extremely small clearances involved. It's not like inkjet where the ink flies through an air gap, the plastic extruded is sort of smeared onto the work as the gap is only around 0.4 to 0.1mm, I'm aiming for 0.2 to 0.1mm layer height on mine.
  4. The Following User Says Thank You to Davek0974 For This Useful Post:
  5. #23
    I just thought it would have to be flat as I've not seen one in any other orientation?
    Neil...
    Build log...here
  6. #24
    Bukito 3D Printer Works On the Go, Upside Down - Tom's Guide ..Clive
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. Talking of 3D printers, slightly OT, but CostCo Watford are selling the Cube 3D printer, 5" cube work area, for ~£825+vat.
  9. #26
    I would actually interested in this if I thought my 3020 machine was suitable.
    Regards,
    Les
  10. #27
    At least delivery is free but +5% if not a member.
    Costco UK - Cubify 3D Printer, Silver
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
  3. RFQ: Help needed to build my first machine NE Norfolk
    By Dorg in forum Projects, Jobs & Requests
    Last Post: 31-10-2012, 09:30 AM
  4. WANTED: Needed for my build
    By jpcnc in forum Items Wanted
    Last Post: 08-01-2011, 02:22 PM
  5. new mashine build advice needed
    By Finrod in forum Milling Machines, Builds & Conversions
    Last Post: 14-10-2008, 11:05 PM
