Thread: Ignoring tool change
15-02-2014 #1
Using Cambam and Mach3.
After writing a program in Cambam with different tool sizes, then continuing to Mach3, the machine doesn't stop to let me manually change tools. I unchecked the "ignore tool change" in Mach3 but no difference.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
15-02-2014 #2
What do you mean unchecked the ignore tool change?
It's a button list in the General Config... where you can select Ignore Tool Change, Stop Spindle Wait for Cycle Start, or AutoTool Changer (which then invokes the tool change scripts).
15-02-2014 #3
Ok Thanks, I tend to forget stuff like this !
Another thing I am getting problems with ; I design a job in Cambam with a cutting pass of 1.5mm. Then in mach3 I set the zero in Z axis and start the Job. The Z plunges straight through my material much more than 1.5mm.... like it completely ignores the data in cambam. This doesn't happen all the time, but quite often.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
15-02-2014 #4
Have you checked to see if the produced G-Code has the correct Z depth?
15-02-2014 #5
Yes. I sorted now. Its something to do with offsets . Its strange because I haven't used anything other that G54 for ages. Anyway, I went though it all and managed to correct it.
15-02-2014 #6
Offsets should have nothing to do with tool changes being ignored.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
15-02-2014 #7Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
Mach3 Tool Change Position
By Mad Professor in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-07-2013, 06:54 PM -
did you change something?
By wilfy in forum General DiscussionReplies: 4Last Post: 29-12-2012, 10:58 PM -
how to change a clip art
By luke11cnc in forum Computer SoftwareReplies: 6Last Post: 03-12-2011, 12:47 PM -
XYZ Centurian 450 VMC tools sticking during tool change (M06)
By craftydonkey in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 19-10-2011, 03:11 PM -
WANTED: Tool holders for T2 (I think) quick change toolpost
By Jonathan in forum Items WantedReplies: 22Last Post: 07-05-2011, 10:30 AM
