    Thanks Gerry, I thought that Vectric's software was able to comunicate with the breakout board directly
    Quote Originally Posted by picyman View Post
    Picman I think you miss understand the role of the Breakout board and Vectric Direct to machine use.
    The BOB's role is mainly to make connections to motors and input/outputs etc easier, they can also provide some protection to your parallel port by using Opto isolators. They can do other things also but essentially all they do is pass along signals and control nothing.
    The Vectric output to machine stills needs some in between software or driver to translate the G-code into Movement. Essentially all it's doing is saving you loading the G-Code into what ever control software runs the machine. The BOB has nothing to do with this other than pass along signals from the control software.
  1. Wiring up the Alarm output on Leadshine AM882
    By Shinobiwan in forum Motor Drivers & Controllers
    Last Post: 01-08-2017, 02:07 AM
  2. Replies: 0
  3. Replies: 1
    Last Post: 20-10-2012, 02:50 PM
  4. HPGL driver output
    By 2006Nobull in forum Computer Software
    Last Post: 07-10-2012, 08:49 PM
  5. 2 Machines 1 Switch for the output - Connections
    By Ian Hart in forum General Electronics
    Last Post: 02-04-2010, 02:33 PM
