Thread: Font cutting
16-02-2014 #1
Hi All
I need a little help Guys please
I am now 56 years old and had a hard life the reason I say this is I am not sure if its my head or brain thats letting me down or my softwear
In Vcarve pro when I do a sign and in single line font , when I ask lord vcarve pro to generate the Gcode it comes up say ,,,20 vectors open 2 closed and he refuses to write the g code for me , can anyone tell me where I am going wrong or not doing or what i should be doing .
The painfull thing about this whole issue is I use to do this easy but now i cant think/ remember what i need to do.
I have now fixed some string to my gloves and put through my jumper sleeves and put a large L and R on my slippers and writing things down.
Please Help
Pete
16-02-2014 #2Have you tried going to the Drawing Tab and then to Edit there is an Object that looks like a necklace (if you hover over it, it says join open vectors) First you have to select all your vectors from the drawing. ..Clive O.A.PIn Vcarve pro when I do a sign and in single line font , when I ask lord vcarve pro to generate the Gcode it comes up say ,,,20 vectors open 2 closed and he refuses to write the g code for me , can anyone tell me where I am going wrong or not doing or what i should be doing .
16-02-2014 #3
Hi Clive O.A.P
Thanks for that
I will try that bud
Now where did i put my glasses
Pete
16-02-2014 #4
I think you have to select text, then right click and select "convert to curves", then as Pete says close vectors.
I have used the "fluting" tool path when being lazy, no need to close all vectors
If you can get away with a true type font, you can just use the engrave tool path button. No messing
Of course it's early in the morning, so all above could be tosh !!!!!!!
16-02-2014 #5
You can't V Carve single line fonts. You either need to use an engraving toolpath as mentioned, or a profile toolpath ON the lines.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
16-02-2014 #6
Thanks All
Got it.......old age is a bugger
Pete
17-05-2014 #7
17-05-2014 #8
17-05-2014 #9
Only by physical age mentally we are all 16
17-05-2014 #10
font software
By kell in forum CAD & CAM SoftwareReplies: 14Last Post: 1 Week Ago, 05:14 PM -
Font help, adding a stand/base to letters so they stand up
By cockneyrebel in forum Computer SoftwareReplies: 16Last Post: 25-07-2014, 12:57 AM -
Cutting Ply/MDF
By Leadhead in forum Wood Finishing Tips & TricksReplies: 3Last Post: 02-10-2013, 01:59 PM -
Hi font help please
By cockneyrebel in forum Computer SoftwareReplies: 3Last Post: 12-04-2013, 06:39 PM -
Russian single line font
By kuki in forum Computer SoftwareReplies: 1Last Post: 18-05-2012, 05:54 PM
